C
calumr135
Hi, this is just a questions for you electricians, I am doing some labouring on site where flats are being built and I have noticed the wiring in them are not under the floor the whole ring circuit has been run loosely where the skirting board is going to be fitted, the cables are sitting in gap in between the floor and the bottom of the plasterboard!
This can't be right surely? This isn't just in one flat they are seem to be wired this way.
I am not a qualified electrician hence the question but even I know this can't be right?
As these are new builds this work has presumably been done by "qualified electricians". I dare challenge them as I will probably be told to **** off.
I genuinely feel for you good guys if this is the competition you are up against, I know you good guys exist and I have seen good electrical work from real electricians who take pride in their work.
Should I step up or should I ignore this?
I appreciate some feedback on this
thanks
thanks
