Just been to the above, the burner will not fire, the fan just keeps running, there are no igniion clicks. Any thoughts? Photocell?
WRONG It also looks for darkness before hand, so if it is faulty it can cause the burner to purge forever. Also since your fixing the boiler you obviously have a oil pressure gauge so connect your pressure gauge to your oil pump and crack open the bleed screw when burner is purging to check for a good flow of oil because if your pump drive coupling is worn it will also cause the burner to purge forever and that may need replacing. If the two of the above are ok you have to look at solenoid coil or control boxThe photo cell only detects a flame to keep the oil on.
have you checked it for soot? give it a wipe.
if its sooty, it needs Harry Corbett.
