Can I combine sensor with switch to turn on lights?
Across 3 floors there are 5 ceiling lights covering the landing and stairs, no natural light.
Currently, the wall light switches turn on all 5 lights and switch off after a minute or 2.
That sounds unsafe.
Where is this? Your house?
Do they not make any sensors with a built in override terminal that allows a light switch to also be used?
I'm sure that they do.
Watch Johns video about this subject.
Oh look, I found one (so more must be out there in the electrical wilderness :) )
Simple answer is yes, but not too sure, what would be the best approach. With smart switches, one can combine PIR's and wall switches, but trying to read the instructions to find out which product will do what is not so easy, as many of the features and not shown with the literature.
I am sure I could write a PLC program to do what you say, but PLCs are not cheap, and I looked at my own house, and I have a couple of PLCs in stock, and thought if I become ill, who could do any repairs? Well, my son could, but it would be better to use stuff designed for domestic use.
View attachment 387455View attachment 387456View attachment 387457View attachment 387458The problem is, the price starts to add up, and until you buy and install, one is still not quite sure will it do what you want? I used all but the motion sensor to allow my wife to turn lights on/off from her temporary bed in the dinning room, and found she used the Google Nest Mini speaker instead of the button, View attachment 387459and the button was reprogrammed to work as a doorbell instead. Our landing light is turned on/off with voice commands, likely not the best idea, but it works.
thanks but need an analogue solution for tenants
I suspect to achieve what you want you’ll need to run additional cables / replace cables
Why do you want to do this ?
What type of light bulbs do you have ?
at most a cable to sensor and then back to light fitting if my idea is correct
The sensor does; the light does not - and indeed must not.
A 'sensor light' is not 'a thing' but a light and a sensor.
So does the light in the 'sensor light'.
Another wire?
the sensor (or sensor light as you refer to it) would be directly wired into the light fitting wiring so it is continually powered regardless of the light bulb being powered
From your description I'm guessing you have a number switches which are each a timer, such as a vacuum typeView attachment 387450
Or electronic typeView attachment 387451
In which case the assumption is all the switches are connecded in parallel and adding a heat or motion sensor to operate all of the lights is a relatively simple addition..
You will have something similar to this arrangement, View attachment 387460we have no idea of the exact arrangements, the junction box shown in the middle may very well be at one of the lights or switches or even at several locations.
To add a sensor to switch all 5 lights on is as simple as 'adding another switch' except that the sensor will also require a neutralView attachment 387461
trying to switch just one light would require:
1. a sensor with a changeover contact (AKA 2 way),
2. permanent live and neutral.
I show the permanent live by changing a cable to 3C&E and using the black core.
My experience of such sensors is they tend to not have a changeover contact (and never if they don't contain a relay)
A 'Sensor light', ie a self contained light with a sensor will not have this facility.
My comment is this is all very do-able but a lot of work.
It is also do-able with smart devices but potentially very expensive
I am aware others have replied since 10am when I started writing this, in the meantime I've been out with my grandson buying his first far, sorting insurance etc, apologies if anything is duplicated but I haven't checked.
Yes, i think you have confirmed i can do it the way I wanted someone to confirm I was thinking i could. i could not quite understand the drawings but I'll explain it in my simplistic way;
In the same way you would connect a mains powered fire detector off a light fitting, you would connect the sensor instead and it would be continually powered. Switched live would run from sensor and connect to the light bulb socket, so either wall switch or the sensor would provide the power and adequate active connections to turn on the light.
There are a few variations depending upon what you want to achieve. The easiest way without additional wiring is to use the existing switch that turns on all lights as the "main power switch" and in normal operation is left permanently ON.
Then wire in each individual assembly to its own sensor controlling just that one particular item (which might be one lamp or a cluster of lamps on the same housing).
With some sensors you could have a number of sensors controlling one such lighting unit, however you need to check that all of those sensors are capable of doing that or they will latch ON permanently because of back-feed (a mains supply at the sensor output leaks thru to the input keeping it switched on basically).
One easy way is to check with the manufacturer.
Usually if you test it and you hear a little click when it detects then it is probably relay operated and will work OK but if no click then it might be electronic switching (Thyristors/transistors and the like) and it might be the type that will not do this.
Alternatively you could add a little relay to the output of each sensor but you would need somewhere to safely house it.
One other way is to wire two up in parallel with one light (both have a Lin at the input that switches to Lout at the output so you L supply goes to both Lin and both Lout goes to the lamp.
Turn them to detect different areas then trigger one detector deliberately and see if it retriggers after the time set or if it triggers using the other detector.
Though this means you need two detectors to experiment with and unless you already have them you would need to buy them or borrow them.
I used to do this trick sometimes with outdoor PIR switches.
Say a couple of PIR floodlights lighting different adjacent areas and two PIR switches detecting two different areas and a linkwire between the two switches.
If the linkwire is actually a simple lightswitch it would allow you to set each floodlight with its own associated detection area and once you had adjusted as required you could throw that switch to the ON position so that either sensor detects and both floods light up.
It did have its benefits sometimes.
You also need to ensure that the sensors were all rated for the maximum possible load of the group they were controlling.
The maximum number in any group I used to do was three sensors usually (I actually did one with 5 sensors and 5 lights and used a six gang switch as the link - 3 PIRs and mini floods on one set and two on the other and all unit could be set independently for testing purposes then the group of three using switches 1, 2 & 3 and the group of two using switches 4 & 5 and the switch 6 would then link both groups together.
Nowadays there are far better electronics/Wifi/Bluetooth solutions that often make things easier.
Yes, the sensor i would use has the click to serve power so i would wire it in conjunction with the existing wall switch operation
But the sensor can be built into the bulb, so I would say calling that a sensor light is reasonable.
However, most of the replies are considering hard-wiring only, and it is possible the distance and walls within the property will only allow hard-wiring, but also we have many wireless devices today, and likely there is a wireless option, and a relayed option.
My landing light is powered from a relay, the relay is hard-wired to the original two-way switches, but is also wireless, and the switches change the state of the relay, does not matter if switched on, or switched off, it detects change of state, so one can integrate wireless and wired together, what I am not sure about is the timed off, although I also see a health and safety problem with a timed off, in a stair well with no natural light.
This is the reason I got rid of my PIR controlled outside lights, being on a set of steps with your hands full of shopping when the lights go off, is not funny, hand full so no waving at sensors, and neither can one put the shopping down, as don't know what one is putting it down on, and until you put it down, can't get phone out of pocket to use its built in torch. So now I use the phone to turn the lights on before I leave the car, and once in house, voice command to turn them off again.
The major problem with so-called smart devices, is working out what they will do before buying.
Also making sure the batteries are charged, my google "Home" app will work all my smart lights, does not matter what make, but the dedicated app there is so indication of battery state. View attachment 387485 Only when using the app for that make, can I see if the batteries are OK. And I have no idea when using timers, if that timer is in the device, the hub, or part of Nest Mini system, I know I can say "hey google turn off bedroom lights in half an hour" and it does, but no idea where that timer is.
There is also the power up state. In the main, a bulb will turn on when power is restored after a power cut, but tried to get an outside light to do that last night, and it failed. The wall switched seem to be reverse, lose power, and on return they stay off. Some will not change state in a power cut, I use light switches with batteries because they do not change state with a power cut.
It may be better to say what the problem is, as there may be another option. Top of my stairs, I had a rechargeable torch, which has built in PIR, and auto lights with a power cut, so should my smart lighting fail, I can still see to go down the stairs.
microwave sensors remove so many of the problems you had with pir. it can detect a body over a wide area, even as you approach from up or down stairs. pir is so limited to what the sensor can "see"
I agree.
I suspect (from experience) it's something like OP is switching on at the bottom and finding the light goes off when they are halfway up the 3rd flight of stairs.
If that is it then operating another switch on the way up is a possible fix... however if it is a single master timer module with multiple slave buttons then subsequent operations are potentially ignored depending on the model/type.
That's not the problem, because each electronic switch can have the time on set. The problem to solve is when you want to pop to the bathroom a couple of metres away and it is totally dark and the light switch for that landing is not close, it's an annoyance to not have the light for just that floor when you want it. Currently i have wall plug in sensor night lights but they are rubbish
This doesn’t satisfy the requirement that the switches turn on all lights while the sensors turn on just the single floor’s lights.
It will not be straightforward to have the sensors activate single lights while the switches activate all five.
Agreed, in fact you could have relays, each in parallel with a particular sensor (with problems of multi sensors I mentioned earlier) and all the relays switched in one group (usually - I will not go into a further possible fudge around that because that brings yet further problems) it usually means extra wires too!
So I would start to rule that out as unwieldly
Bar using something like a PLC this is about the best he's going to get.
One option would be separate lights. Keep the existing lights operated by the switches; add entirely independent lights operated by (built-in) sensors.
