Can I create a circular path with block paving?
27 Mar 2009
Yorkshire
Could someone please suggest how I might best create a circular path please?
I have lots of blocks left over from my new block paved driveway, but im not sure if they are the best product for this project?
I havent dug the area out yet, but Ive roughly marked the area as can be seen in these photos. The intention is to plant a bush in the centre circle, with a circular path surrounding it.
As much as I'd like to make use of the block pavers, Im not sure that they are the way forward for this project. Perhaps I should dispose of the pavers and look at an alternative product, such as paving flags or stepping stones spaced out with gravel in-between? Or perhaps a paving circle kit but with the middle circle removed?
23 Feb 2007
Belfast
on a radius under about 3m block paving starts to look very gappy as the blocks don't fit tightly. this also makes maintenance difficult as the wide gaps grow weeds profusely.
If you are incredibly patient you can taper every other block with a grinder but its probably easier to forget it.
You can use setts which are the very small blocks and they come in a circle kit with blocks already cut.
see here
http://www.tobermore.co.uk/tegula_circles.aspx?AspxAutoDetectCookieSupport=1
27 Mar 2009
Yorkshire
I like the idea of those sets, thanks. I could always miss out the middle circle to allow for the bush to be planted.
Great idea, thanks :)
22 Apr 2013
Northamptonshire
might be easier to create the inner and outer edge of the circle with block on edge and then just pave it in straight lines with your blocks otherwise you will have a lot of cuts to get the circle inlay
otherwise return or sell the left over blocks and buy the sections of circle you need
27 Mar 2009
Yorkshire
Thanks for the replies. I think a circular paving sett kit is what I need. I now just need to find one thats about 3.2m diameter...
22 Apr 2013
Northamptonshire
those in the pic look like there all 100mm x 100mm setts just spaced to get the curve rather than having the edges cut to form the radious
27 Mar 2009
Yorkshire
Your probably right, it's just a random google picture. I would of course buy a kit with tapered blocks. I'm going to visit a few builders merchants and see what they have.
