Hi all
I've seen diagrams of taking a spur off the switched socket, adding a light switch and then onto a wall light but can I do it the other way around?
I have no other switched socket in my hall close without any obstacles to create an extension or take a spur off but directly above where I want the socket is a light switch for the under stairs light.
Questions:
1. Can I take a spur off the light down the inside of the wall and add a 1 gang switched socket?
2. What's the difference between single and double pole with these switches, what should I use?
3. If the above is OK and I go ahead, is it safe to change the light switch to a "switch to break" door switch inside the door frame so I can switch the light on when the door opens? Option 3 is the least important.
Here's a pic of the back of the switch if that helps.
https://picasaweb.google.com/107828...key=Gv1sRgCPbKqt79n8mg6wE#5658435078224669570
Thanks for any advice.
BTW I'm happy doing the wiring myself, adding the socket etc and have already added a floodlight to the outside of my house to an existing outside switch but could do with some pointers.
Gary
Questions:
Gary
