Good luck with your project! I'm just completing our guest room en suite with multiPANEL sheets......costs a bomb but the result is wonderful. The sheet edging trims are great too. I'm using the T&G lock together stuff and the join is nigh on invisible.......you just need to get your cuts right first time.....
John
I used the spirit based grab adhesive, with a couple of pins through the tongues.......I did brace the panels with laths from the opposite wall on occasion, just to apply a bit of pressure where it was needed.
John
John
John
Sure, it's Evo Stik Gripfill, in a green tube.....I'm using one tube per sheet and it's sticking fine.
With the T and G stuff, even the tiniest curve on the wall can make the joint show slightly but I think it's much better than the joining strips.
I managed to get the showering area covered with only one internal corner join so I'm quite chuffed with that.
John
John
Shower all got fitted last week, with thanks especially to SandyLyon for the guidance.
Only issue is the plumber didn't bury the pipe quite deep enough on the hot, so there is a very small gap behind the plate on this one. But life goes on
