Just when I thought it was over another challenge appears, help please! I have 6mm cable running from my consumer unit (30amp Fused) to my large on/off double pole control unit in the kitchen. I have a 6mm spur from the control unit( existing setup). My new hob appliance uses 6.2kw. My existing 6mm spur cable will not fit, Manufacturer say's if you can't get it to fit use 4mm. Can I run 4mm cable from the 6mm fed large on/off double pole Control unit.
On The hob where the cable goes in, it says (3 x 1.5 Max) what size cable is this????
Thank you...
Kumbi
Thank you...
Kumbi
