Can't get parts of the ceiling white
30 Jan 2014
Essex
I'm renovating a bedroom in my mum's house that had fitted furniture. Where I removed the wardrobe and wall cupboards, it exposed the parts of the ceiling that haven't been painted for nearly 30 years.
I've given the ceiling at least 6 coats of Crown Emulsion but it just isn't matching the rest of the ceiling.
When I did the kitchen the ceiling was thick yellow from all the grease and it didn't take this many coats.
I don't know what I'm doing wrong. Is it the paint?
I would say it is the paint.
I have experienced the exact same problem with some DIY Crown emulsion.
It was like dishwater, it looked like it should cover, but it didn't - useless rubbish.
I think Crown do an 'obliterating' version which does cover well, or try a 'trade' emulsion.
Thanks. Think it's the first time I've used this paint and had some marks on the wall that were also still bleeding through with 3 coats.
Time to try something else I guess.
I once purchased 10L of white Crown retail emulsion. It only cost about a tenner.
It was so awful that I binned 9L of it.
You could try Stain Block [as above] or use a flat oil paint then emulsion?
If all else fails lining paper and emulsion?
I would start with stain block? easiest and fairly cheap?
Ken
Thanks for everyones replies.
Three coats of Dulux did the job. I won't be buying Crown again.
Glad you got it sorted.
Personally I am not a fan of crown paints but (with caveats) the crown trade paints are usable, their retail range however should only be sold in pound shops.
