Car reg after a private plate?
22 Jul 2016
I am looking at a car tomorrow, a dealer (small one)
It was a single owner and had been on a private plate, they are refitting a normal plate
It has a FSH
Obviously I will ask when I see it but one question would be
Is it normal that a car owner would hold a new car’s original registration to pass on when the car is sold?
I am asking as obviously I will do checks on the car and don’t know if the VIN would be of any use when checking for damage/insurance.
I have only used a cheap check about £5 for one other car but would spend more to get better info
TIA
If the car had a traditional plate on it when first registered, then it will revert to this number if the owner of the plate takes the number “off” the car
If the car had the private plate on it when it was first registered, then a new number will be allocated to it when the private plate is removed
Hope this helps
My current car had a private plate on before I bought it and it reverted to the original whilst at the dealers before I bought it, it did take about a year or something for it to start showing up properly on websites when you search for car parts etc. I've never taken the number plates off to check what's behind in the 9 years of ownership.
It'd be a very small amount of damage if it did. No more than a normal registration plate - do you worry about damage behind regular registration plates?
I think he means any accidental damage that occurred whilst registered as the private plate. Not damage to or behind the plate itself.
And no, it shouldn't. But as always, damage and repairs can be done without any formal insurance recordings.
To be clear I did mean that I wondered if the plate would have influenced any search for crash damage under its original / now plate.
I did a check and it picked up the plates changes and indicated that it searches for both.
So no (reported) damage in it’s life either on issued or private number
Checking the deal and making a decision over the weekend
AFAIK any damage will be recorded no matter how many registrations have been applied. These vehicle checking companies have an accurate history of the vehicle, servicing, mot’s, mileage, ownership changes etc.
Can you search that kind of thing with the VIN.
You should be able to. DVLA certainly can, but maybe you can't do it on the freebie ones? The manufacturer will record everything (warranty work, service history, etc) by VIN. The VIN is the only part of the vehicle's identity that can never change.
