carpenter/joiners
Good question, & while we're at it - a 'clamp' and a 'cramp'?
I was told many years ago that a joiner makes the stuff off site, windows,doors, staircases etc. and a carpenter fits them on site as well as all the other woodwork required in the building, 1st & 2nd fit.
Don't know if that's completely accurate but it makes sense.
Clamp & cramp, one holds together, the other forces together, just a bad guess really. :idea:
Adhesive & glue, no idea, I'm stuck for an answer (cutting edge or what) :lol:
I make no bones about it, i think that reply was a bit tacky, but i think you should stick with it :)
A joiner 'joins' (makes) things, a carpenter fixes the finished item. I know carpenters make joints in roofs etc, but that's the original meaning. You wouldn't normally get joiners working on building sites, nor carpenters in 'joinery shops'.
A clamp doesn't involve screw threads to fix itself (but possibly to ADJUST itself), but works with a sudden action, like a Mole wrench. A cramp tightens by means of a screw thread.
Adhesive and glue are surely the same thing...
Screws and joints? You're not serious are you, Thermo?? If you need to know what a screw looks like, just ask. :wink:
________________________
moderator
polite note, see 17
hey its not an old post now so i can reply!
i meant a joiner would use proper joints in a piece of work built in a workshop, in preference to screws used on site by a carpenter!
