Carpet Quantities advice needed
22 Dec 2007
Cheshire
Hi Guyz
My carpet fitter is on holiday, The wife has found a carpet she likes, so Im ordering it up for when the fitter is back, can anyone let me know please how many m2 I would need to get please
Room 1
4.3 x 3.8
Room 2
3.73 x 2.8
Room 3
2.2 x 1.82
Landing
3.5 x 1.7
Stairs i have 13 Stairs
900mm wide
Tread is 250mm deep & 200mm high
the sizes above are exact sizes
I can work out the rooms, but i have offcuts that may do the stairs etc, this is where I get stuck,
thanks in advance if anyone has the time to work it out for me
Al
A carpet fitter isn't just going to arrive with so many square metres of carpet, he's going to arrive with bits of the requisite size for the various rooms, cut to order in the most efficient way from the width of a roll of carpet. You can't just order so many square metres of carpet.
Cheers
Richard
The Carpet fitter is not arriving with the carpet the carpet is being ordered direct from our flooring supplier, we hold accounts with numerous suppliers.
So the fitter has asked me to order the carpet from the supplier so its here for his first job. Which after he has finished, and putting me in the good books with the wife, he is going onto our school work, Im trying to get this squeezed in to be done for the wife, in between our school refurb work
I am fully aware mate of it being cut form a roll, I was hoping to get the landing of an offcut of one of the bedrooms etc, hence my reason hoping there may be a helpful fitter who has a couple of minutes to spare to work it out for a fellow tradesman.
Why don't you find out how wide the roll is and work it out on a bit of graph paper?
The roll is 4m wide, Thanks for your help mate, thats what Im in the process of doing, Im trying not to waste any, which is the pain the bum bit
Don't forget the pattern match and pile direction
its plain carpet mate, pile direction, not a lot we can do on the landing it will run across the stairs,
Al
11.6m of a 4m wide dead plain roll if you are OK with joints on the stair run.
That's maths not a carpet fitters calc.
Diag attached
Thanks for very much for your efforts Tony,
I nipped into our suppliers earlier this morning and they worked it out for me,
Hi bigal993
First thing I would do is add 10 cm per room length to allow for cutting in the carpet, so
Room 1
4.4 x 4 = 17.6 SQ MTR
Room 2
2.9 X 4 = 11.6 SQ MTR
Landing
1.8 x 4 = 7.2 SQ MTR
Not enough waste from these areas to find the stair carpet
Room 3 and stair
2.8 x 4 = 11.2 SQ MTR
SPLIT THIS DOWN THE CENTRE SO YOU HAVE 1 PIECE 2.8 X 1.92 THIS WILL FIT ROOM 3
THE REMAINING PIECE IS 2.8 X 2.08 WHICH WILL FIT THE STAIR IN TWO PIECES, EACH COVERING 6 STAIR TREADS
THE 13th TREAD WILL COME FROM THE ROOM 3 WASTE ( 1.92 x .5 )
This way the carpet pile on the landing and stair carpet is laid correctly brushing down the stairs.
You could order this in separate cuts or 1 roll
Other guys might have other ways to plan it but this would be my way
Regards Ron
