I am currently building a two-storey extension to my cottage and there are two carriage arches in the new-build. Does anyone know how to build the perfect arch? Would I be better off using a curved steel beam with plates welded on? Or would you use a wood former and build the arches in brick then knock the former out after to use as a template for the frames. The width of the arches is 2500mm, one is a garage door and the other is door set into a frame. How are brick arches best built? Many thanks.
