I suppose such rules do not apply to things from which it is impossible to receive a shock.As I keep saying, maybe I'm missing something - but I read the regulations as saying that the 'third option' does not exist - i.e. protection against electric shock has to be provided by either an earthed metal casing or by double/reinforced insulation.
Plastic light switch on plastic pattress - what would be the point of actually making it a compliant Class 2 item?I'm obviously not saying that one should even think of 'earthing' a non-conductive casing (c.f. a plastic water pipe), but my reading (perhaps/probably wrong) suggests that if there is not a metal casing to earth, the only other available 'allowable' option is for it to be Class II.
That from which it is impossible to contact the 230V ?Do you therefore believe that there is some acceptable option (regs-wise) which is neither Class I nor Class II?
Obviously not.You seem to feel that a 'plastic (or wooden, or whatever) box' affords adequate protection, but does it not have to qualify as "double/reinforced" insulation (i.e. 'Class II') in order for it to be 'allowable'?
I don't know, other than there must be rules for the manufacture of such things.I imagine you would not accept a box made out of paper or cardboard, and that you would not accept a covering of PVC tape. What about a thin/flimsy plastic box? Where are you drawing your line?
