I replaced two horrible candelabra things hanging from my living room ceiling with simple pendants. As I understand it, there should normally be wires coming out of the cieling, but I just had screw connectors, so I had to take the wires out of the pendants and put them in the ceiling. I wired them both exactly the same, and they worked at first.
However, after about two hours, one just went off by itself. Tried the lightbulb in a different room to see if it was fused, but it works. The fuse on the main board is not tripped. I've opened up the switch, but everything seems fine in there. I've even tried opening it up again and replacing it with a third pendant but it still won't work. The other one still works fine.
Any ideas what I might have overlooked?
