- Joined
- 26 Jan 2017
- Messages
- 7
- Reaction score
- 0
- Country
Another question regarding my garage conversion. I am struggling with insulation for the roof.
The garage is detached from the house.
I have recently had the flat roof replaced with a EPDM roof. It sits on 150mm rafters. It is a cold deck roof. I was planning on using 100mm celotex in between and then 52.5 insulated plasterboard. But as it is a garage my height to ceiling is already low. 2290mm. I still have 80mm floor insulation plus 18mm flooring, plus finished floor, so I was thinking that maybe I would fill the ceiling void right the way up to the deck with 150mm celotex and then put a vapour barrier underneath the rafters before attaching uninsulated 12.5mm PB.
Re the 150mm celotex, I know that there should be 50mm ventelation but I can't see how I can have a vented cavity as how would the air flow past the rafters that would be at parallel with the vents - there are no vents at the moment. Or I would have to put a lot of vents along the side of the garage between each rafter. Anyhow I can't see how I can have a vented void. So I was thinking 150mm so that I don't need insulated PB underneath or thinner insulated PB if I do need it. Does this seem reasonable?
I am assuming that the insulated PB is to stop thermal bridging, but I may be completely wrong but I can't see how it's a major issue with 150mm wood. I am happy to be told otherwise. I am an amateur at all this and so any help and guidance much appreciated. I really want to order some insulation so that I can get cracking.
Also, I rang Building Control before I started doing any of this and they told me that I didn't need to notify them about any of the garage conversion. With this in mind, although I am trying to stick to target U values and building regs I am also not tied by them (as far as I am aware).
Sorry for rambling post, fell like my head has been insulated after spending all day trying to work out what to do.
