Hi there and thanks for running a great site. Never thought I'd end up having to leave a post here tho! My problem is as follows and I need some advice on how to go forward, legally or otherwise?
My partner in September 07 paid £1800 to have a 'contractor' remove a c.h boiler from a back bedroom and install a new Biassi boiler in the loft. Since then she / we have no hot water (central heating works ok) no reply to numerous texts to get him to contact us etc to resolve.
I got personally involved with this and he shows up three weeks ago to fix a genuine leak in a downstairs rad and look into the problem further. He gets in touch with Biassi in Wednesbury and they advise him to check filters and other things etc in boiler, still no joy. He ends up getting a new boiler from Biassi, turns up on doorstep and tells us this will cost £200 to install?
After installation, no change, i.e no hot water. He now thinks its the gas pressure. removes the steel 3/4" pipe from gas meter downstairs to under floor of upstairs landing and replaced it with 22mm copper. From landing to rear bedroom. I notice he has replaced 15mm pipe he had tapped into originally to run the 22mm pipe to the loft. He then goes on holiday but informs us his 'mate' will contact us to check gas pressure before and after meter, although in past I had asked if gas and water pressure were up to spec pre installation and informed gas ok, but water not his issue? Anyway his mate did not call and today we got in touch with him (the installer) and he is now saying its not his problem but the gas pressure.
So, at this moment in time we are no further forward. I'm sorry the story rattles on but just need some info on how to go forward with this? I am in process of checking to see if he is corgi registered, although he has the 'orange' shield on his van, there is no registration number below it. I don't think my partner at the time of getting this guy in, asked for his I.d number.
Thanks for any advice you may be able to offer.
Tony
Tony
