Hi, im in the final stages of installing the pipe work for my central heating. I have run 1 22mm pipe as the flow from the boiler, and one as the return, with 15mm pipes leading from the flow through a trv/radiator and back to the return.
does the 22mm pipe flow need linking with the return with some sort of restriction?. As I worry if all the valves are closed I could end up with the relief valve opening.
Also the flow and retun run through the loft as we are in a bungalow, should I put some sort of bleed valve on the flow and return to make filling easier?
mark
mark
