I'm a newbie here so bear with me. I have a Baxi Bermuda back boiler. I have hot water but no heating to radiators. I have a room thermostat in the lounge and a tank on the airing cupboard. This system have been working without any problems for the last 5 years. I think the problem is the Lifestyle mid position valve (based on what I have read here in the forum).
The valve does not move when heating is needed, stays on W position. The back boiler does not kick in. When I manually move the switch to M or H position I can get hot radiators so at the moment its on that position. If I let go, it will go back to W position (with or without power). When water heating is needed, boiler kicks in.
My questions are.
1. Am I right to say that the mid position valve is at fault?
2. If it is, is there any fuses or just part that is potentially the problem?
3. if i need to replace the whole valve, do i have to bleed the whole system? How to do it?
4. if I need to buy the valve, is it just a straight swap with the latest model? Can't find old model. I have the Lifestyle 679H340-3OLO (£55 + Vat)
Hope someone can help. thanks
My questions are.
