In each house, one for ASHP flow, another main UFH flow to manifolds then one per UFH manifold on each floor of house so 4 in the two storey houses, 5 in the three storey houses.
The plumbers installed 12 heating zones in all four of the 4 bed houses and fitted 12 Heatmiser NeoAir thermostats each requiring independant programming. They fitted the bathroom floor stats (set to air reading) on the walls outside of each bathroom.
As the manifold is controlled by a UH8 wifi unit, I swapped all my stats to the NeoStat version which can be controlled via their app, has blanket profiles, copy and paste etc. A whole lot easier than running around the house every time I went away for a week.
Consensus is not to zone the Samsung ASHP but to run it in water law (weather compensation) and leave all zones open on low and slow heating. As mentioned, the plumbers had never done an ASHP install before and it took some time to get Samsung to issue the warranty document. To add to their workload, they installed Viessman for two houses and Samsung for the other two and I've discovered they have two different operating philosophies. Viessman installs using W Plan with the three port at rest in heating mode and the Samsungs on S Plans.
As mentioned on another thread, plumbers wired 13A fused spur to Samsung controller using 1.5mm flex not realising the controller needed 13A once a week to run the immersion on it's Legionnaires cycle.
Now I've tweaked stats, flow valves etc, we use c 8,000 KWHr a year whereas our neighbours are consuming upwards of 13,500 KWHr/year for similar lifestyle/usage.
Since I started this thread, to wrap it up, contrary to what the plumber told me that it was not possible without moving the boiler, that was complete rubbish.
Once the left cover had been removed, (two screws) although access to the two flange nuts was not easy, it was not a complex job to remove and replace. Had to drain the header tank (obviously), hack saw to split the flange nuts, but it all went together pretty easily.
And I did not move the boiler! Nor did I need to replace the gate valves.
Now to query the invoice for telling me that he could not do the job!
And yes, it is not the highest quality most expensive pump but I will take my chances.
Yes, just replaced the nuts. Having closed the valves, there was always a chance of gunk sitting in the seat and nt getting a solid closure. But when I tried to release the nuts, they had kinda 'welded' themselves to the pump thread and the pump could be slightly rotated on the vlaves. The result was a constant drip.
So drained the header tank and allowed the dripping to drain the pipework before cutting off the nuts.
But most importantly, having fitted the pump and opened the valves, there was were was no dripping.
Interesting, seems opinions differ. I only have DIYer experience. I've always had Grundfos, apart from first house in 1973, new build with an SMC pump. Odd thing, it had female threaded connections, 1" IIRC. Changed it for a UPS 15-50.
