I am in the process of specifying a new central heating system for a Victorian 2 bedroom semi detached house. Initially the system will provide heating via conventional radiators and hot water. I am adding a loft bedroom; this will probably have under-floor heating, mainly due to lack of space for radiators and a second bathroom.
My main priority is making sure that the new system is as efficient as possible.
From my research to date I have come up with the following solution:
System boiler, sized correctly (not too big), I am thinking around 10Kw.
Un-vented – indirect cylinder, around 185 litres.
Intelligent controller with outside temperature sensor etc.
I would like to add some solar heating in the future, so a twin coil cylinder might be the solution. If possible the controller would also be able to look after the under-floor heating and solar water heating as well.
I have looked at using a heat bank solution (GXV) from DPS, but I gather from this forum that these are more suitable for very large systems.
I would really appreciate some feedback on whether I am going along the right lines and more specifically any suggestions on the best boiler / tank / controller to go for.
