I've just purchased a replacement SMEG hob model SE2641TC1.
As you can see from the attached photo there is a sticker across the terminal board which states "Warning: Not to be used for the wiring connection".
There also appears to be cabling already present; it looks like 1.5mm multistrand stuff; nowhere near the load carrying capacity one would expect is required of a ceramic hob. Certainly its a lot smaller than the 6mm cable that attached to the previous hob and which I was proposing to use.
I'm a little confused, I don't like to ignore Warning stickers and as there is no other way of connected the hob I'm a little stuck. I thought I would ask you fine chaps for suggestions!? Many thanks
