Changing hot tap in system fitted with Megaflow
21 Jul 2007
I've just moved into a new place which is fitted with a Megaflow system. Which unhandily has come with no instructions :(
I want to change the hot tap in the bathroom but I've no idea how to drain the hot water system/ Megaflow system. Could someone help explain how I'd go about doing it please (I guess it's not as easy as isolating the cold water supply to the Megaflow and then opening all the hot taps is it :)
Thanks in advance
Great - thanks :)
How about afterwards? Just leave all the hot taps open and then turn the cold water supply back onto the Megaflow or is there a bleeding sequence to get rid of any airlocks?
close hot taps apart from the one furthest away from cylinder, open cold feed and allow to fill until water issues from tap, close tap and open next tap until water issues, repeat on all hot taps. megaflow is now full and purged of air :wink:
