- Joined
- 20 Nov 2007
- Messages
- 3
- Reaction score
- 0
- Country
Hi
Just moved into a new place with a separate lighting circuit already built in with the round 3 pin 5A sockets controlled by dimmer switches.
I presume it will be ok to simply change the 'normal' off the shelf plugs on the two bedside lamps and a couple of standard lamps in another room to make use of these?
The lights all have standard bulbs and there would only be max of 4 in use. This shouldn't overload anything should it? Am I missing anything obvious that I should bear in mind?
Many thanks in advance.
