I am buying a chest freezer to put into my garage, install in garage is a 10mm SWA from 40amp breaker in house CU running 32m to a 2way RCD CU in the garage with 32amp MCB supplying sockets and 6amp mcb supllying lighting.
The CU in the garage is not a split load board it is all covered by RCD, will it be ok to put the freezer on the this setup or will it be prone to nuicance tripping?
