Hi there,
My Grandad asked me round to put up some pendants he had bought. Seen here.
As you can see they are metal and class 2. He has a loop in lighting system so I used terminal block to connect the appropriate wires. The PN for the lamp connect in a small contained terminal block in a small white housing. So I was happy that this surficed the double insulation.
What concerned me was that there was nowhere in the ceiling to put the terminal blocks (loop/neutral/cpc) I had to leave these in the ceiling rose part of the light fitting (which is metal like the rest of the fitting). I am no expert but I can't imagine this is anywhere near double insulation. There is no option to connect a CPC so worries me this is potentially dangerous.
Unfortunately I didnt bring the installation instructions home, only the above piece (because I needed to order a new lamp diffuser that was broken in the box). On this is does say "g) If it is not possible to fit excess cable into ceiling void, cut the cable, prepare wires and reconnect into terminal block."
So are they assuming that it has to be wired in the feed to switch (I believe thats what its called) method for their instructions to apply.
Im hoping I've made this clear. To make this safe I guess I need to connect a CPC somehow. Do you think its worth a call to the manufacturer to ask advice.
Thanks for your help,
Chris
edit: changed image location.
Chris
