CLASSIC COMBI
21 Aug 2007
does anybody know how to test a wax stat think mine is sticking causing overheating problems (only happens in CH mode) all advice gladly received
no way I know of checking it
and I may be being thick but I have never heard of a classic combi and as far as I know only the puma had a wax diverter
There is a Classic Combi.... just a diverter valve, EV, and calorifier bolted onto the top. Very Heath Robinson. ahem.
Dunno about testing the stat though... Only seen a few in operation and took one out.
I agree Dan, an Ideal classic ff80 I think with what looks like a 'Y' plan stuck on the top with an expansion vessel :shock:
thanks so far, the model is a NF80 don't know if this will help. the wax stat is on the top right side on the flow outlet pipe. held in place by two large nuts.
try putting the waxstat in a bucket of hot water you will find if the valve is working correctly it will be fully open at 74deg c, also check the small bypass hole is not blocked.
The ideal man may be able to confirm this or not as the case may be.
an NF80!! a Combi?????
well you can knock me down with a feather I have never seen one
blimey you can teach a reasonably young a virile dog new tricks
Fetch Corgi, Fetch :lol: :lol:
thanks un sure will try that, does anybody know who's "the Ideal Man" sig is? is he an ideal engineer? might know of an easy way to remove, drain etc.
thanks to all who took the time to reply :)
sausages
(and if you know what I am on about you are giving away your age ;) )
gas4you said:
Yes I can just about remember :oops: :( :lol:
you old fart (just like me)
so want will it be
a party seven or a badger brown
:lol: :lol: :lol: :lol: :lol:
(or mebbe a double diamond???)
A double diamond works wonders, works wonders!
In those days it was Ben trumans export draught :lol:
LMAO
jaysus 4 we are getting auld matey
I must stop trying to pull 18yr dolly birds
FECK I said "dolly birds" that ages me too
If you can remember what the four magic feathers did in four feather falls then you've really got something to worry about as far as age is concerned.
