Cleansing limescale from shower screens?
You should see fizzing if it's working. Just keep wiping off then squirting more on until it's gone.
Obviously it's easier to maintain rather than letting it build up. But it will get rid eventually.
Keep away from strong acids, they can do a lot of damage. Glass can be deliberately etched with acid to produce a frosted effect. It was also used with a stencil in the old days to security etch your reg no on the side windows of your car.
E.g. don't accidentally do this by taking some of the suggestions above!...
If once you have got it clean you use a window squeegee to wipe it down after every shower then the problem should not re-occur.
Hello
What’s the best way to remove limescale that’s built up around a shower screen seal that I plan to replace? Scrape? Use a cleaner? Knife?
Cheers
That seal strip will pull off. Make a note of which way around it goes.
