I have, clearly you haven't beyond the abstract because they cover that in the method and results.
This is a variation of a standard scientific approach, a meta study. They are used to combine all the research on a topic together and in so doing refine it to get a better picture than individual studies could on their own.
And one thing they found very clearly is that the greater your knowledge of climate science, the greater the consensus.
Again, which study was discredited? I know the one you're thinking of, it's C13, and i know which attempt to discredit it you meant T16, but i don't think you do know what those papers are. Off you Google.
Lavish grants? Can we at least cut out the nonsense and waffle?
Ok, let me spell this out for you since you probably haven't ever worked in research.
Let's say I have a PhD in Psychology. I need to earn a living and I have a decent shot at applying for some grant funding which is related to climate change. Here is my hypothesis:
"Violent crime has increased as a result of climate change"
In my abstract, I might write something along the lines of:
"There is a consensus that CO2 emissions contribute to climate change and that rising CO2 is causing the climate to warm. This research paper explores whether global warming results in an increase in violent crime by considering the rate of such crime recorded in the city of Troy, Ohio between 1950 and 2020..."
Now, any researcher worth his salt will obviously have a section about limitations. Maybe there's no obvious relationship, or maybe there is but other variables need to be explored, etc.
Point is, the consensus estimating researchers will come along with their meta analysis, covering thousands of research papers which they will never read in any detail at all, do an electronic search of terms and find in my abstract, and probably elsewhere in the document, that I have stated that "rising CO2 is causing the climate to warm." I will be added to the list of "active climate scientists" (because I am studying a climate related topic) and added to the list of those who think CO2 is contributing to climate change.
I, with my poxy BS research paper and my PhD in psychology, having never even considered the causes of climate change itself, and knowing nothing at all about it, am now one of the 97%!
What is laughable is that the consensus estimators are even worse grifters because they are basically producing misleading research about research. Crap on top of crap. A significant proportion of research is total rubbish and a waste of tax payer's money.
So you have to think things through and understand the details. To even mention the 97% consensus is automatically discrediting. It is a con.
