    Dismiss Notice
Clipsal 30M Light Switch
Discussion in 'Electrics UK' started by Mad_Doctor_X, 6 Jun 2009.
  1. Mad_Doctor_X
    Mad_Doctor_X
    15 Feb 2008
    24
    Thanks Received:
    Country:
    Hello!
    Looking for a bit of reassurance before I plod on...
    I've got at clipsal 30M two-way light switch in front of me and it has four connections on the back of it. Three of them are labelled 'Common', 'L' and '1' so my thinking is that the L and the 1 are essentially L1 and L2. But the fourth connection has a small piece of breakable plastic blocking access to it and is labelled as either '3', or more probably 'T'. Any ideas as to what the fourth terminal is for would be most welcome!
    Cheers
  2. electronicsuk
    electronicsuk
    7 May 2007
    3,316
    Thanks Received:
    275
    Lincolnshire
    Country:
    An intermediate model of the same switch?
  3. Mad_Doctor_X
    Mad_Doctor_X
    15 Feb 2008
    24
    Thanks Received:
    Country:
    Nah! I've got one of those and that hasn't got any labelling next to the terminals at all!! :eek:
    (It's on a label around the terminal block!)
  4. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,063
    Thanks Received:
    1,913
    Oxfordshire
    Country:
    Send us a pic, but I think that a couple of minutes with a continuity tester should tell you all you need to know :?:
  5. Mad_Doctor_X
    Mad_Doctor_X
    15 Feb 2008
    24
    Thanks Received:
    Country:
    Doh! Thanks for that.
    Continuity testing revealed that 'common', '1' and the plastic covered 'T' are Common, L1 and L2. The terminal marked 'L' is not in continuity with anything regardless of the position of the switch. While fiddling with it I noticed that the terminal is a little thicker than the others (see below).
    [/img]
  6. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,063
    Thanks Received:
    1,913
    Oxfordshire
    Country:
    Ahh.
    L probably then is for "loop". Used to bring a live (or neutral) in and then out again without it being a part of the switch function.
  7. DIYnot Local
    3 Sep 2019
    Country:
  8. Sponsored Links
Loading...
Share This Page
