Co-ordinating pipework with flooring sheet
19 Feb 2015
My bathroom floor has pine floor planks which need replaced. The pipework to the basin taps runs under the floorboards.
I have been considering having the boards replaced with sheets of marine plywood, with floor tiles on top.
If I were to install a wall-hung basin with exposed chrome pipes going from the taps down to the floor, with pipe collars at the base (similar to photo), how would someone co-ordinate the correct drilling locations for these in the sheet to precisely where the pipes would meet the floor?
Even if it is possible to drill the holes in precisely the correct location, how would it then be possible to connect the vertical pipes to the underfloor elbow (since that would be under the plywood sheet)?
The same issue would apply to connecting up the radiator.
Maybe it's issues such as this why some keep this type of pipework above the floor.
iu
Its best to conceal the pipe work in the wall. Then your floor is left untouched.
Same for the towel rail.
But if you want to do it that way then the pipe work is installed (pressure tested) before the floor is laid.
Personally I think the basin would still just look crappy in chrome pipe work up from the floor and would need a pedestal.
The issue with that is that it is a load bearing wall between my bathroom and that of my neighbour's.
How is the floor left untouched? Even if the pipework is in the wall, does it still not have to go under the floorboards?
Yes, but you've already said you're taking the floorboards up so that shouldn't be a problem. The new floor won't need to be cut to fit the pipes if you run under the floor then up the wall
