After looking at some thru-crimps on some redundant cables I had dragged out of a fuseboard and being a bit concerned that they didn't seem too good of a joint I set about doing some tests..
I was using a CK rachet crimp tool, so reasonable brand etc. What I found was when crimped a joint initially seems sound, but if you put a 90 bend in the conductor and try and twist it, it'll twist a few degrees side to side... not a massive amount, but enough that its evident that the conductor is moving inside the terminal, this is even evident even if 2.5mm conductor in a blue crimp is crimped using the red/1.5mm dies!. This seems to be caused by the deformed part having sideways play as the crimp is still able to resist lateral force; a 2.5mm² through crimped conductor snapped at a point other than the joint when pulled to breaking point... yet if you tried turning the conductors, you'd get movement
Either I need a new crimp tool urgently, or there is a fundermental problem with this kind of joint... I don't have a problem with crimping in general, its just that the small ones seem a bit... micky mouse
