I have a 3metre concrete lintel (100mm wide). It has a rough side and a smooth side - which way up should it go?
And what would happen if it went the other way up
Cheers
Paul
We did put the flat side down, and that was the side with the wire in.
The problem is that it looks like it is bowing in the middle, but it hasn't got any load on it.
1. Pre tensioned. The steel wire is under tension before the concrete sets, . . .
Tha t would not work.
The steel is tensioned after the concrete sets so it compresses toe concrete - you can't do this when the concrete is wet.
