Concrete mix query
29 Oct 2007
Coventry
4 bags of ballast and half a bag of concrete, out of interest what strength would this achieve?
After how many days? - it gets stronger every day it sets.
Normally a 6 to 1 or a 5 to 1 ratio (not the 8 to 1 that you are suggesting that is a very weak ratio), gives between 2500 and 4000 psi for normal concrete according to this link (noting they have a typo saying 25000 rather than 2500).
https://www.aboutcivil.org/compressive-strength-of-concrete.html
Why do you need to know? Building a bridge? Hopefully not with that 8:1 mix.
Sfk
Half a bag of 'concrete'? You mean you are diluting concrete with ballast?
The correct (standard) mix is four parts ballast - two parts sharp (screed, grit) sand - one cement. And water of course.
Half a bag of 'concrete'? You mean you are diluting concrete with ballast?/QUOTE]
Yep that's correct the 25kg ballast bags I'm referring to mixed with half a bag of concrete
Wanted to know what strength will that achieve? i.e c20 c25 etc
Is this mixed in a barrow, with the garden hose or controlled batching with known water content, measured slump value, and vibrated?
Its half a bag of Quinn 25kg cement mixed with the 4 bags of ballast, water added into a mixer
Gotcha. It will provide you with a weaker than standard 6:1 mix but not by much. Why the scientific measuring for the strength of concrete? Are you building a dam?
Concrete is not cement by the way.
If its any help that's a similar ratio my builder used for a mass concrete pad foundation
