- Joined
- 14 Feb 2005
- Messages
- 102
- Reaction score
- 16
- Country
Hi
I asked this in the building forum and it was suggested I ask here instead.
Our house is constructed on a slope and the concrete plinth at the front (I think that is what it is called - the concrete render that runs along at ground level to stop water splashing up onto the bricks) is about 2 ft high. The gas meter is attached to the house on at this level i.e. screwed through the plinth to the brick.
Unfortunately, the concrete has come away from the wall and there is a gap of about 1/2 to 1 inch along most of it, which we need to remedy as vegetation tends to grow out of it and it lets rain run down, which causes slight damp in our living room. The only problem is that the gas meter is in the way and would need to come off (it is hanging off now as a result of the concrete coming away). I assume the plinth would need to be chipped off and re rendered. This means that the gas meter couldn't be put back straight away but would have to be off the wall for a while.
Does anyone have a suggestion as to the best way of going about this? I assume Transco will have to deal with the meter. Is it best to shut off the gas meter for a short period whilst the work is done and then reinstate it later (which I assume would mean two transco visits) or is there another way that anyone can suggest. The pipes feeding it come straight up from beneath the drive, up the front of the house and into the bottom of the meter box, so it can't be moved away from the wall without messing with the pipes.
