concrete slab and drain advice
1 Mar 2008
Bradford
Hi
I want to rip up an area of 5mx5m tarmac and replace it with concrete slab(4", about 2.5m3 i think) to use as a dog run. I know how to lay sub-base etc, but wanted some advice on details.
I think it will need dividing bays (will be getting ready mix), and I wanted to include a linear drain ( into existing rainwater drain. Area has exisiting garden/house walls on three sides, so whats the best way to lay it and include boundary and bay expansion/contraction (12mm flexcell) joints in one day/pour. (i.e how to tamp down when you only have access to one side)
no mesh reinforcement planned!
Or an I trying to be too clever and should just use 4x1 all round and then remove and fill in gaps (though am DIY to don't have access to hot bitumen and professional joint fillers seem very expensive)? Also want to minimise chance of dogs scratching it out.
thanks
A note of caution, connecting a drain into the rainwater drain maybe an issue. Dog fouling/wash down should really be directed into a foul drain.
noted, but they(2 dogs) already have the run of the drive way. when they do foul it I clean it up any residue already goes into the surface water drains. Its not a commercial thing.
