Confused of lighting circuit.....Please Help!!!
13 Nov 2008
Lincolnshire
I have replaced a light fitting from my living room. The light had a dimmer which I replaced with a standard two way swith. On replacing the fitting a noted the wire locations and fitted the new fitting to the ceiling. ( 5 wires in , all reds blocked , all blacks blocked , earths blocked and the switch wired located ).
On refitting and checking the light worked. Until I switched the dining room light. The both lights came on but flickered in doing so and once settled the living room light dimmed considerably.
There are five lights in the circuit and the living room light on works fully when switched alone.
I am real confused as to why this is happening.
Can anyone advise me what to do?
Any advice will be much appreciated
Stu
Bad connection most probably,
Remove the switch and light fitting re check ALL connections, even the ones that you didn't make, they might just want a tighten.
Ah, miss read the question. Yeah, Holmslaw, if both lights come on, could be a borrowed neutral,
Before working on the light, isolate the other lighting circuits to just to be on safe side. Borrowed neutrals can nip your hand a bit if you dont know they are there!!
Thanks for your replies, ok now it is a very old fuse board. One fuse for all the lights.
Could anyone help - in simple terms how on earth to locate this borrowed neutral and............what on earth can I do to sort this out.
yours hopefully ( desperately )
stu
If all the lights are on one fuse then it won't be borrowed neutral (well not from the lighting circuit anyway).
