Connecting 6mm to hob cable
30 Apr 2008
Manchester
I’m connecting a hob cable to a 6mm via a whiska weatherproof junction box underneath the cooker.
Do you know what gland sizes I need for the flat 6mm cable is it 20mm or 25mm.
Also what size wago connectors do I need I can see the 4mm ones on Screwfix but do they do a larger one.
The tenant is moving this week and have no time chiselling the wall to put a flush mount box and don’t think a surface mount one fits in. I’ll have a look, unless I put it I. The cabinet next to it
Can I actually place it here the cooker outlet?
Or attach it to the back wall?
This would be my choice, fixed to the back wall
toolstation also do larger wago,s
Stuffing glands for twin and earth use special grommets 1684831007864.png it depends what your local suppliers have in stock, no good asking on here if in a hurry, need to ask your suppliers. From what you say internet buying will be too slow.
I ended up installing a flush MK cooker outlet, it didn't take that long as the back was a breeze block easily drilled out.
I did use a 47mm flush box that was a bit deeper than expected. Used a standard grommet, 6mm cable went through fine.
The problem is I did not use a mask while drilling this black dust and ended up with diarrhoea during the night. My body thought it was a virus!
I had the same issue before with brick dust. I really need to wear goggles and a mask!
A few weeks ago I was drilling a brick wall for another cooker outlet, when I woke up the following morning I opened my right eye and must have been brick dust logged into my eyelid went straight into my eye and blinking made it worse. I ended up on the eye hospital emergency department where the doctor said I scratched it and gave me drops for a week!
I still have the habit of showering at night. To me, it seemed daft to have a shower in the morning then get filthy during the day.
