I have a light/fan in the conservatory in which the bulb went.
I put a new bulb in ( actually an old one as I had no new ones at the time ) as I put it in it flashed and went straight out. Then I got a new bulb and nothing will work now. I checked the switch and all is OK from the switch to the light as I put a temporary live to the switch to make sure the light would work and it did.
I assume I have a broken supply to the switch, sadly it goes under a fitted wood floor so access is not good.
Any ideas ?.
Thanks.
Any ideas ?.
Thanks.
