Hi, last year I made some small lockers for my pseudo campervan using 6mm mdf - they were fine and looked OK but I'd like to redo them with an updated design and a bit more strength (so Plywood is likely).
The problem is I am no carpenter and the corners were tricky, in the end I used ugly connectors and screws which had to be filled and painted - OK but not great.
I've been thinking about alternatives but despite searching online and B&Q etc I cant find what I am looking for.
Hard to describe so I drew a picture of a profile that I think would work.
Has anyone seen anything like this (aluminium I think would be best for strength and weight reduction) but I'm happy to look at anything.
Happy that the edging is on show as long as it's presentable (again a metal would look good although I guess PVC may be OK too).
Failing that, how do I join thin panel together without adding considerably to the bulk or needing specialist tools ? I've tried searching the forum but nothing obvious springs to mind. Hints on attaching hinges to 6mm board is particularly welcome (I used araldite last time).
Any help appreciated, thanks all.
