Electrical regulations and fire prevention is aimed around stopping an electrical item causing a fire, not fire damage to an electrical item.
With an electric cooker there are no real regulations on how close items can be, with the induction hob I use if you can get to the pans, that is enough room, items need to be within ½ inch of the hob to allow it to turn on and heat them.
So the regulations stopping the fitting of the consumer unit would be gas regulations not electric, common sense says you should not mount some thing above a heat source, on another forum I found I would guess other makes are around the same.
I have found thisbut it would seem your consumer unit is likely higher than 750 mm above the hob, so I can't actually find a regulation electric wise may be better to ask on plumbers section who are more into gas regulations.![]()
Sorry, could you rephrase that?He means no!
That position is not allowed for a simple switch, let alone a consumer unit.
There’s a whole heap of regulations and common sense reasons that it MUST NOT BE ABOVE A COOKER OF ANY SORT.
Is that clear enough?
I am afraid Part P does not say that - although what it does say might result in the same outcome, so don't quote that one.Part P of the Building Regulations states that there should be no outlets or accessories (cooker hoods excluded!) above any type of hob, nor within 300mm of the edge of the hob.
I certainly agree that there is more than enough in BS7671 about 'environmental conditions' ot preclude the installation of a CU (and probably many/most other electrical items) above a gas hob, as illustrated.... There is a particular regulation that may prohibit the installation of a socket (or anything) above the hob and thats the gas regulations, these require that there is no combustable materials within a certain zone, also the manufactuers will state the same....
Didn’t realise that you had caught some sort of pedant virus from our friend! perhsps I should have specified the Approved Document and not the Statutory Instrument. But, hands up, I just copied that from somewhere else. It may not be at all true.I am afraid Part P does not say that - although what it does say might result in the same outcome, so don't quote that one.
That's it. There is no more.
I don't think that anyone should be holding their breath.....mind you, the housing association may be planning to enclose the whole in a nice cabinet.
seemed OK until you zoom in on the little hole top lefts and see this
but it was not the electrician at fault, when he fitted the fuse box it was a garage with no suspended ceiling, and daft as it was, the person who really made the error with the LABC inspector who should have said you can't do that and insisted it was altered before issuing the completion certificate. So the cooker switch ought to be moved as well?Part P of the Building Regulations states that there should be no outlets or accessories (cooker hoods excluded!) above any type of hob, nor within 300mm of the edge of the hob.
