is it right to use one short piece of brown 2.5mm t+e to that left hand side choc block which looks like it then goes to a ring? Is it possible that the short section could become overloaded if the ring was used at a high load or is this the way it should be done![]()
the choc is the least of his problems![]()
Yep, I bet it's not got a label on the front warning about wiring colours to two versions of BS7671 either...![]()
Prize goes to RF Lighting then - neutral to the RCD should be fed into the top not the bottom of the module as he has done.
