dandt said:then get an electrician to do the important links to and near present ringmain/spur socket [hard to describe, I know what I mean]
I will then check that I am happy with all the connections after he's gone
pbar said:Hi again. Appreciate what you're saying, however, no electrician I've ever had in to do work as done the tests you mention. They simply wire everything up, turn on, yes, everything works, then they go.
I've no doubt that there are guys (like your good self, like others on here), who are very trustworthy, check everything, then check again and are totally reliable. But, in my opinion, most are not. They are more like -connect it up, it works, thanks for the money, see you.
pbar said:We determine that we are capable, if we know what we are doing and are certain it is right. I am capable of wiring a plug, fitting a spur, replacing a socket, replacing an MCB, etc.
pbar said:We determine that we are capable, if we know what we are doing and are certain it is right. I am capable fitting a spur, replacing a socket, replacing an MCB, etc.
It can prove fatal but rarely does. All our installation norms are based on continuous ratings of the cables even though in most cases they are only used intermittantly so things like broken rings aren't anywhere near as bad in practice as they first appear. When cables do fail they tend to fail with a bang and some smoke but rarely fire because the plastics used to make the cables are self extinguishing. Disconnection times are unlikely to be an issue on a domestic with type B breakers unless there is something wrong with the suppliers earth or the breakers are really out.scousespark said:Getting it wrong can prove fatal and results in a court case and a stretch inside.
