The point I was making Plug was that the stats would indicate that most of us are working to a safe standard. If most of us were of the 'connect up switch on and walk away' mentality the instances of dangerous installations would be much higher.
GaryMo said:pbar said:We determine that we are capable, if we know what we are doing and are certain it is right. I am capable fitting a spur, replacing a socket, replacing an MCB, etc.
EEBADS? Will the circuit disconnect in the required time (0.4s / 5s)? How would you check?
That's part of the course of determining if it's safe or not, not by plugging in a table lamp.
scousespark said:pbar said:How can you be 'certain you are right'. I do this job every day and only know it is right after I've tested and confirmed results are acceptable.
So...is what you're saying that no one should ever (for example) even be allowed to fit a plug because of the lack of test equipment.
When I fit a plug I test it by plugging the appliance in. It works, so success. Of course I ensure proper connections are made, cable grip is attached properly, no bare wires, etc.
As I've said, common sense.
It's the same common sense I use when I change a tap washer, lay some concrete, fit some skirting boards, mow the lawn (oh, my wife does that, never mind), plaster repair, fit guttering or do any other number of DIY tasks around the home.
scousespark said:Then again you keep telling us that you always have to check their work and make it better.
pbar said:I wouldn't check. I would take great care to connect everything up properly using common sense and making sure the work I was doing was within my knowledge and experience. I would make sure everything works, that I am happy, and job done.
Connect it, it works, walk away. Just like every electrician I've ever met.
GaryMo said:pbar said:I wouldn't check. I would take great care to connect everything up properly using common sense and making sure the work I was doing was within my knowledge and experience. I would make sure everything works, that I am happy, and job done.
So, you'll walk away uncertain then? Even though the circuit could have had problems before you touched it? Blinkers are a wonderful thing.
As long as the table lamp lights up eh![]()
scousespark said:Pbar,
I am not disagreeing that some people don't do the job properly. From your posts you've been unlucky. But, think of how many electricians you have seen working. The chances are, you've not met that many.
As for the levels of testing, there are a list of tests an electrician should follow. The number of tests will depend on what you are doing, but the results will still need to be acceptable. When you add a spur, the ONLY way you can know it is safe is by testing it using equipment which is known to be accurate. Checking all the screws are tight and the cables look neat does not prove it is okay.
I get a feeling that no matter what we say, you have an opinion that we are all sharks who want to fleece every penny from Joe Public, and do shoddy work. In reality, most of us are honest and do our best to ensure that the work we do satisfies our customers (and is safe).
