Conveting kitchen base unit to two seperate units
28 Jun 2021
Hi
I have an usnused base unit of 615mm space, pls see photo, door is fitted but not in use. I want to convert it to 2 units, one for 150mm pull out and and second for 450mm integrated dish washer. The plan is:
1. Cut the door 597m in the photo to make 2 doors for each of the 2 units: 147mm and 447mm. Paint edges.
2. Fit 150mm base unit and 3 tier 100mm pull out, pics attached.
3. Fit integrated 450mm dishwasher. Cold water and waste are already available next to the unit.
4. Filler strip if required.
Is the above workable? Which unit to fit first if matters? Any other considerations?
Yes all that will work. You will need fit the 150mm unit first to set the 450 gap for the integrated dishwasher. If however there is any pipework running behind the 600 base unit your are ostriscing, the pipe work will need moving or the dishwasher wont go back far enough.
You will also need to put some silver tape at the front edge under the worktop to stop the steam damaging the worktop.
Unless you really need the storage, I would just put in a standard size dishwasher.
