Just got my self a Electrolux Built in combi microwave oven that has a connected load of 3000W. It is going along side my existing 3.5KW Electrolux steam oven.
While a 13A BS1362 fuse will just about take this 3000W Load, the manual is ambiguous. On one hand it says;
What suggests it has to be wired directly to a 20+ Amp isolator, but then the manual also says.
How should I connect it?
Can you get a twin cooker isolator that has two 20+ Amp outlets? Also is it permitted to connect two single ovens to a single DP isolator?
Regards: Elliott
The cable used to connect the oven to
the electrical supply must comply to the
specifications given below.
For UK use only
Connection via: Cooker Control Circuit
Min. size Cable/flex: 2,5 mm²
Cable/flex type: PVC / PVC twin and earth
Fuse: min: 15 A/max: 20 A
- Make sure not to cause damage to the mains plug and to the mains cable. Contact the Service or an electrician to change a damaged mains cable.
- Connect the mains plug to the mains socket only at the end of the installation.
Make sure that there is access to the mains plug after the installation.
connect the mains plug.
- If the mains socket is loose, do not connect the mains plug.
Regards: Elliott
