hi guys, this is a great forum. everyone seems really helpful.
here is my query, have a new cooker and ceramic hob. i have connected the cooker to a switched fused spur from the ring main and all seems fine.
i have come to wire in the hob, its rated at 6.2kw which is about 25A? the label for wiring it up says to use 2.5mm cable, is this too small? i have a 4mm connection already in place but the cable wont fit into the terminals. could i run a short length of 2.5mm from the connection plate to the hob as the run back to the fuse box is still 4mm?
does that make sense
