- Joined
- 27 Jan 2008
- Messages
- 28,083
- Reaction score
- 3,408
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I came across a web site here which tries to compare cooking costs. Now I have noticed my new oven heats up far quicker than my old one and also stays hot longer after switch off. So clearly not all ovens are the same.
Since the oven has a 32A supply I can't test to see how much energy it uses. However it seems rather suspect to give how much a "Typical" oven uses as it is so variable.
I also fail to understand how one can Roast a chicken in a microwave? It would require some device to convert microwaves into radiant heat and I can't see how using something to convert the heat would be cheaper than doing directly with a cooker designed to roast items. If it was cook a chicken yes could understand how a microwave could be cheaper, but not to roast.
I see the point about excess water. However using a simple trivet food can be kept off the pan base and with a good fitting lid food can be cooked with very little water. I have a stand alone unit which can both steam and pressure cook, in both cases water used is very little.
I wonder what the microwave manufacturers pay the web site.
