- Joined
- 22 Aug 2006
- Messages
- 7,600
- Reaction score
- 1,373
- Country
I think some doctors are paranoid about addiction.No, i havent got any. I mentioned the bad back pain that has been worse over the last 2 weeks to doc today but he didnt give me anything....
Only the Pregabolin for the burning nerve pain...
I found tram helps for the burning nerve pain more than it does for the stabbing one.
Gabapentin and Pregabalin are almost the same, I was told. Pfizer produced the pregab just to get some market share. They tweaked the molecule, so it takes less mg for the same effect.
With Gaba you can take a much higher dose than is usually prescribed, I take 3 - 3.6 g/day. You can probably do similar with P - see the sheet.
I started taking Gaba when it first came out, pre 2000 sometime. It's more times per day which is a bit of a nuisance, I should switch. I'm never sure if it's doing much, plus the side effect is feeling generally sh1t. P was produced later.
Thr Tramadol helps, not a complete fix for nerve pain. I get sciaticas in my legs, it dulls that right back.
I'd post you some but that's probably frowned on...
