D
Deleted member 105431
by fluxing the fitting you are putting flux in the pipes which is very corrosive and particuarly on gas this can rot the pipe from the inside out. Excess flux in central heating systems causes accelerated corrosion leading to sludge and pinhole leaks. Fluxing the fitting can cause it to fill with solder causing blockages too.
