Correct cable for external flood.
8 Jul 2008
Derbyshire
I have looked at a few previous posts regarding this, but wanted a clear answer.
I am swapping out a rusted 500w spot for a similar one.
I am not getting an LED flood as I don't like them. Either the drivers die or the LED dies and then you have to buy a whole new one unless you want to spend the time disassembling it to try and fix it.
So I am getting a normal 500w flood (Timeguard) but using the LED equivalent replaceable bulb at 100w+ equivalent.
However....the current cable going to the flood is a bit ropey.
It looks to be a normal "gray" internal spec (Twin and earth?) cable.
I assume it should be some kind of exterior quality UV stable instead.
What type of cable should I use. It is only a short run from an isolation switch in the garage.
Based on the other threads, would this be the correct pick?
https://www.tlc-direct.co.uk/Main_Index/Cable_Index/NYY/index.html
1.5mm seems to be the minimum but I'm sure is more than enough for a flood.
Or is there something more generic that would work?
Yes.
It's a nice cable to dress neatly also(due to it's solid cores, not stranded), it stays put when you bend it, unlike flex which wants to spring back.
so that's a good choice for external fixed lighting? I see it's UV resistant.
it looks round so glands would seal round it.
I need something in my carport.
Yes, just be aware it's thicker cable, 10.5mm-ish diameter vs 8.5mm-ish for 1.5mm² flex, the gland could end up quite large. I would use a gland where possible also, definitely better than cutting a cross in the provided blind grommet, as long as there's space for it.
